Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
Miked2
Mar 06, 2025Apprentice
Restarted my cable modem this morning and got: Cable Firmware Version V10.01.03.
Speeds went from 600/20 to 700/42. Still not as fast as when I used the Comcast modem and got 700/100, on this same plan. So, it is better, but it seems not totally what it should be able to do.
Kitsap
Mar 06, 2025Master
Miked2 wrote:Restarted my cable modem this morning and got: Cable Firmware Version V10.01.03.
Same plan at this same address?
You should be receiving the same down/up throughput as you received with the Comcast gateway.
The 600/100 plan is offered in my area. With over provisioning (+20%), you should be testing out at around 720/120.
Maybe try another restart of your modem and the router connected down stream. If that does not help, you may need Comcast to confirm your modem has the appropriate boot file for your plan.
- FURRYe38Mar 06, 2025Guru - Experienced User
Id' also post the cable connections and event log data pages for review as well.
- Miked2Mar 06, 2025Apprentice
Here is the connection info. Not sure what is should be! Rebooted modem, getting 700/41.
Is anyone getting 100MB uploads with the new firmware?
Thanks
Cable ConnectionCable Diagnostic Status: Good Action:
Your setup looks fine. If you can't access the internet, make sure you properly activated the modem. If modem has been activated and you still can't access the internet, contact your service provider for troubleshooting help.
If you can access the internet but has other internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.CM Status: GREEN Downstream Status: GREEN Upstream Status: GREEN Advanced Information Frequency Start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 543000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD IPv6 only Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 28 543000000 Hz -1.2 dBmV 44.3 dB 0 0 2 Locked QAM256 1 381000000 Hz -1.7 dBmV 44.2 dB 0 0 3 Locked QAM256 2 387000000 Hz -1.4 dBmV 44.3 dB 0 0 4 Locked QAM256 3 393000000 Hz -1.5 dBmV 44.3 dB 0 0 5 Locked QAM256 4 399000000 Hz -1.7 dBmV 44.2 dB 0 0 6 Locked QAM256 5 405000000 Hz -1.5 dBmV 44.3 dB 0 0 7 Locked QAM256 6 411000000 Hz -1.9 dBmV 44.0 dB 0 0 8 Locked QAM256 7 417000000 Hz -1.8 dBmV 44.2 dB 0 0 9 Locked QAM256 8 423000000 Hz -1.8 dBmV 44.3 dB 0 0 10 Locked QAM256 9 429000000 Hz -2.0 dBmV 44.2 dB 0 0 11 Locked QAM256 10 435000000 Hz -1.8 dBmV 44.3 dB 0 0 12 Locked QAM256 11 441000000 Hz -1.8 dBmV 44.3 dB 0 0 13 Locked QAM256 12 447000000 Hz -1.7 dBmV 44.3 dB 0 0 14 Locked QAM256 13 453000000 Hz -1.4 dBmV 44.5 dB 0 0 15 Locked QAM256 14 459000000 Hz -1.5 dBmV 44.5 dB 0 0 16 Locked QAM256 15 465000000 Hz -1.3 dBmV 44.6 dB 0 0 17 Locked QAM256 16 471000000 Hz -1.1 dBmV 44.6 dB 0 0 18 Locked QAM256 17 477000000 Hz -1.2 dBmV 44.6 dB 0 0 19 Locked QAM256 18 483000000 Hz -1.0 dBmV 44.7 dB 0 0 20 Locked QAM256 19 489000000 Hz -1.0 dBmV 44.7 dB 0 0 21 Locked QAM256 20 495000000 Hz -1.2 dBmV 44.6 dB 0 0 22 Locked QAM256 21 501000000 Hz -1.0 dBmV 44.6 dB 0 0 23 Locked QAM256 22 507000000 Hz -1.2 dBmV 44.5 dB 0 0 24 Locked QAM256 23 513000000 Hz -1.2 dBmV 44.6 dB 0 0 25 Locked QAM256 24 519000000 Hz -1.2 dBmV 44.6 dB 0 0 26 Locked QAM256 25 525000000 Hz -1.2 dBmV 44.6 dB 0 0 27 Locked QAM256 26 531000000 Hz -1.1 dBmV 44.7 dB 0 0 28 Locked QAM256 27 537000000 Hz -1.2 dBmV 44.4 dB 0 0 29 Locked QAM256 29 549000000 Hz -1.1 dBmV 44.4 dB 0 0 30 Locked QAM256 30 555000000 Hz -1.2 dBmV 44.5 dB 0 0 31 Locked QAM256 31 561000000 Hz -0.9 dBmV 44.5 dB 0 0 32 Locked QAM256 32 567000000 Hz -0.9 dBmV 44.5 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 45.8 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 45.8 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 46.0 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 46.3 dBmV 5 Not Locked Unknown 0 0 0 0.0 dBmV 6 Not Locked Unknown 0 0 0 0.0 dBmV 7 Not Locked Unknown 0 0 0 0.0 dBmV 8 Not Locked Unknown 0 0 0 0.0 dBmV Downstream OFDM Channels Channel Lock Status Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 193 690000000 Hz 0.78 dBmV 44.5 dB 388 ~ 3707 43954523 10473840 0 2 Locked 0 ,1 ,2 ,3 194 957000000 Hz -1.42 dBmV 43.2 dB 148 ~ 3947 44421919 13305640 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Locked 12 ,13 41 36200000 Hz 42.0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Current System Time:Thu Mar 06 12:34:34 2025 System Up Time:01:57:51 - FURRYe38Mar 06, 2025Guru - Experienced User
Cable connections looks good, Please post the event logs data as well.
Try a power OFF for 1 minute then back ON. A reboot may not be enough.
