Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
Mar 18, 2025Guru - Experienced User
For those with the CM2050v and this version of FW, you'll need to make contact with the ISPs regarding speeds expected and supported by the ISP. They will be responsible in getting the speeds up to expectations on there side. NG has handed off FW to the ISP and it's now all in there hands. Nothing else NG can do.
Kitsap
Mar 20, 2025Master
We have a confirmed CM2050V liftoff from a user on the East coast. No firmware update, but most likely a boot file update. See attached.
On Reddit: https://www.reddit.com/r/Comcast_Xfinity/comments/1iy1hzh/comment/miuxubz/
