Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
Miked2
Mar 05, 2025Apprentice
I am in Maryland on Comcast. My firmware has not been updated yet. I get 600 Down and 20 Up now. I tried a comcast modem some months ago and got 600 up and 100 down. Hopefully I will get upgraded soon and I should get the same as the comcast modem, I think!
donawalt
Mar 24, 2025Hero - Experienced User
Miked2 what does Comcast say your plan speeds should be? Bring up the Xfinity app,, Tap Account at the bottom, then manage your plan, then scroll down to the Internet section and you'll see your download and upload speeds.
- KitsapMar 25, 2025Master
A CM2050V user in Chicago has reported receiving upload throughput consistent with Enhanced Speed Network values.
https://www.reddit.com/r/Comcast_Xfinity/comments/1iy1hzh/comment/mjqkivi/?context=3
