Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
donawalt
Mar 24, 2025Mentor - Experienced User
Miked2 what does Comcast say your plan speeds should be? Bring up the Xfinity app,, Tap Account at the bottom, then manage your plan, then scroll down to the Internet section and you'll see your download and upload speeds.
Kitsap
Mar 25, 2025Master
A CM2050V user in Chicago has reported receiving upload throughput consistent with Enhanced Speed Network values.
https://www.reddit.com/r/Comcast_Xfinity/comments/1iy1hzh/comment/mjqkivi/?context=3
