Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
Jun 17, 2025Guru - Experienced User
All aspects of the modem working? UI accessibility and stability?
Kitsap
Jun 17, 2025Master
Everything I have checked has worked reasonably well. Including the VPN server running on my router.
Occasionally it takes more than one attempt to successfully log in to the UI. Once in the UI, it may take a couple of tries to bring up the cable statistics or the event log. The eMTA log and call log work fine.
