trialcritic's avatar
Mar 01, 2025
Netgear CM3000 No upstream channel locked - no light
I have an Xfinity Gigabit X2 plan. I restarted my CM3000 modem and Orbi 970 router. I see that the upstream channel light is Off (implying No upstream channel is locked). I restarted the modem twice...
  • plemans's avatar
    Mar 02, 2025
    Your values look pretty spot on. could be just a burned out led. If it bothers you, you can always return/exchange it. But if its working fine, you could just ignore it.
