Topology
Oct 03, 2023Virtuoso
NETGEAR CM3000
The Xfinity list of Recommended Devices for Our Internet Plans now references a NETGEAR CM3000 unit. What might this be? Perhaps it is a forthcoming cable modem that supports DOCSIS 4.0?
Kitsap
Oct 03, 2023Master
Topology wrote:The Xfinity list of Recommended Devices for Our Internet Plans now references a NETGEAR CM3000 unit. What might this be? Perhaps it is a forthcoming cable modem that supports DOCSIS 4.0?
That list has been revised/updated several times. The most recent version, dated September 25, 2023, shows the CM3000 listed as compatible but not listed as recommended for the Comcast pre 10G network. Until a number of the units are actually deployed and connected to the Comcast network for a time, it most likely will not move into the recommended category. Eventually it should have full Comcast approval for their 10G network.
On the Charter-Spectrum list of approved modems, the CM3000 is listed as a DOCSIS 3.1 device. Attached is the OEM manual. The technical specifications are on the last page.
NICETOUCH
Dec 19, 2023Aspirant
I received an email from Xfinity as early as December 18th, 2023, recommending the NETGEAR CM3000. Hopefully, I can find this product sooner rather than later. It would be helpful if Xfinity included, in the email, stores where we could purchase the product.
- plemansDec 19, 2023Guru - Experienced User
Xfinity has been showing it on their increased upload speed page for a while so I'd imaging its forthcoming.
