STW18
Sep 13, 2018Aspirant
Netgear CM400 Modem Worked with Spectrum now won't work with WOW
I used a CM400-1AZNAS modem with Sprectrum. I have switched to WOW. The Wow technician said that the modem seems to have gotten an update from Sprectrum that keeps it from working on WOW. A factory r...
vkdelta
Sep 13, 2018NETGEAR Employee Retired
Most likely it is because Modem is locked to IPv6 and WoW does not support IPv6.
- STW18Sep 14, 2018AspirantIs there a way to unlock it?
- vkdeltaSep 15, 2018NETGEAR Employee Retired
Pls PM me.
- Bux1234567Jan 28, 2019Aspirant
I have had the same problem. How can the CM400 be unblocked after my using it with Spectrum and now that I want to use it with WOW!?
