STW18
Sep 13, 2018Aspirant
Netgear CM400 Modem Worked with Spectrum now won't work with WOW
I used a CM400-1AZNAS modem with Sprectrum. I have switched to WOW. The Wow technician said that the modem seems to have gotten an update from Sprectrum that keeps it from working on WOW. A factory r...
vkdelta
Sep 13, 2018NETGEAR Employee Retired
Most likely it is because Modem is locked to IPv6 and WoW does not support IPv6.
STW18
Sep 14, 2018Aspirant
Is there a way to unlock it?
- vkdeltaSep 15, 2018NETGEAR Employee Retired
Pls PM me.
- Bux1234567Jan 28, 2019Aspirant
I have had the same problem. How can the CM400 be unblocked after my using it with Spectrum and now that I want to use it with WOW!?
- TomasmeMar 02, 2019Aspirant
I am having the same problem. WOW technician was at my home today, but he couldn't get my CM400 to work since it had been used with Spectrum service (locked on IPv6). Can Netgear help with this? How do we unlock the modem to work with WOW? This is a modem I had purchased from Amazon, and I'm very unhappy that Spectrum locked it.
- DarrenMMar 07, 2019Sr. NETGEAR Moderator
you may need to contact support see if they can do anything for you.
https://www.netgear.com/support/contact.aspx
DarrenM
