wmolebash
May 13, 2020Follower
NETGEAR CM400 only getting 24mbps
I have a NETGEAR CM400 that purchased in 2016 because I felt it would be pretty future proof. So far, I've been very happy with it. Today, I called Spectrum to see if there were any new promotion...
NashDavid
May 30, 2020Tutor
I was having disconnects when working remotely and zooming. Speedtest shows slow upload speeds, about 5, all locations, all computers.
Comcast says "there's a modem problem". I can't get ethernet to connect directly.
Failed modem? How can I tell before I buy a new one to see?
- plemansMay 30, 2020Guru - Experienced User
NashDavid wrote:I was having disconnects when working remotely and zooming. Speedtest shows slow upload speeds, about 5, all locations, all computers.
Again, you need to look at your subsribed upload speeds. many plans on like 100mbps down and 5mbps upload. or 200mbps down and 10mbps up.
I pay for 1gig (1000mbps) and only get 30mbps upload. Its significantly worse upload becaue its cable and not fibre.
That's what I want you to check. 5mbps might be your upload speed.
You can also log into the cm400 and check its cable connection page. Take a screen snip of it and post it back here. that lets us get a snap shot of your cable connection.
And when you connect a pc directly to the modem, you'd need to reboot the modem. Anytime you change what the modems connected to, reboot it.
- NashDavidMay 30, 2020Tutor
You were correct, my plan only allowed 5 mbps upload. The problem is disconnects and problems with Zoom disconnects, delays. Slow speed was initially suspected; the Comcast person checking remotely said there was a modem issue.
How can I tell if it's the modem? The big cost of a new modem is the time spent with Comcast activating it. Considering new modem and/or going to ATT fiber... and increasing Comcast speed.
Haven't been able to direct connect to modem yet, son is working and don't want to interrupt...
Ideas appreciated...
so the question comes down to modem or router.
The modem basically provides what speeds it can.
If your subscribed to 100/5 service and the modem is providing it, then its either a router issue or you need to upgrade your speed.
Try your zoom meetings hardwired into the modem. If everything works fine, then the bandwidth is plenty and its a router issue.
What router are you using?
Were you getting the full 100mbps download?
Are you zoom meeting on 2.4ghz, 5ghz, or wired?
