wmolebash
May 13, 2020Follower
NETGEAR CM400 only getting 24mbps
I have a NETGEAR CM400 that purchased in 2016 because I felt it would be pretty future proof. So far, I've been very happy with it. Today, I called Spectrum to see if there were any new promotion...
NashDavid
May 30, 2020Tutor
I was having disconnects when working remotely and zooming. Speedtest shows slow upload speeds, about 5, all locations, all computers.
Comcast says "there's a modem problem". I can't get ethernet to connect directly.
Failed modem? How can I tell before I buy a new one to see?
May 30, 2020Guru - Experienced User
NashDavid wrote:I was having disconnects when working remotely and zooming. Speedtest shows slow upload speeds, about 5, all locations, all computers.
Again, you need to look at your subsribed upload speeds. many plans on like 100mbps down and 5mbps upload. or 200mbps down and 10mbps up.
I pay for 1gig (1000mbps) and only get 30mbps upload. Its significantly worse upload becaue its cable and not fibre.
That's what I want you to check. 5mbps might be your upload speed.
You can also log into the cm400 and check its cable connection page. Take a screen snip of it and post it back here. that lets us get a snap shot of your cable connection.
And when you connect a pc directly to the modem, you'd need to reboot the modem. Anytime you change what the modems connected to, reboot it.
