wmolebash
May 13, 2020Follower
NETGEAR CM400 only getting 24mbps
I have a NETGEAR CM400 that purchased in 2016 because I felt it would be pretty future proof. So far, I've been very happy with it. Today, I called Spectrum to see if there were any new promotion...
NashDavid
May 30, 2020Tutor
Linksys ac3200
My zoom is 2.4. My sons have frequent disconnects on 5.
So will buying a better modem/router (suggestions) and upgrading to 300/15 fix it?
Getting full 100 on 5 when close to router.
Thx!
Thx!
May 30, 2020Guru - Experienced User
Again, try the zoom hardwired in. The max bandwidth (supposedly) for zoom running in 1080p is 3mbps.
https://www.reviews.org/internet-service/zoom-technical-requirements/
If you're only running 1 zoom meeting at a time, you should be able to hit that. running multiple and you could be short on upload bandwidth.
