DavidParcell's avatar
DavidParcell
Follower
Mar 10, 2019
Netgear CM400
I had to replace my cable modem today for the internet. The new modem works fine, but I cannot connect to my security cameras from my desktop or phone. I know I need to reset something. The old server address was 68.7.66.65, what would be the server address for this unit? 192.168.100.1 does not work. Thanks in advance.
David Parcell
david_parcell@yahoo.com
1 Reply
  • > [...] I cannot connect to my security cameras from my desktop or
    > phone. [...]
       Not a very detailed description of any of these devices, or how
    they're employed.
       "cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.
       How, exactly, are you trying to "connect" to your (unspecified) "my
    security cameras"?  Some app?  Web browser?  (Actual URL?)  Are you
    using your public IP address?  Do you know what that is?
    > [...] The old server address was 68.7.66.65, what would be the server
    > address for this unit? [...]
       That depends on your ISP (Cox).  A CMxxx is a simple cable-TV modem,
    not a modem+router.  Your (unspecified) _router_ is the device which
    should get your public IP address, and that doesn't depend directly on
    your modem.  Talk to your router to determine its WAN/Internet address.
    Or, visit one of the many "What is my IP address?" web sites out there.
    > [...] 192.168.100.1 does not work.
       Regarding "does not work", see "cannot", above.  What kind of "does
    not work"?  "192.168.100.1" should get you to your cable-TV modem, but
    it does not have the answer; your router should.
       If your public IP address is subject to change, then you might want
    to explore "Dynamic DNS" ("DNS") services which your (unspecified)
    router may support.  That would allow you to use a (fixed) DNS name
    instead of a (variable) IP address.  The DDNS system should keep the
    name pointed to your (wandering) public IP address.
