MatheusB32323
Jun 04, 2021Aspirant
Netgear CM500 flashing red downstream
Hey so I like JUST purchased a Netgear Cable modem and I set it up by putting the coax in and ethernet out. I got power, then the downstream was flashing red, and I thought nothing of it. The etherne...
MatheusB32323
Jun 07, 2021Aspirant
The connection is good, I used it for a cable tv box with MOCA and it worked. Also I have verizon fios, and yes I know fios is a fiber optic connection, but the cable that feeds the coax splitter that then goes to my room comes from the ONT for MOCA so you can watch youtube and such on your FIOS TV box. I am simply using the modem as a access point to put the ethernet in my PC for better response time and speeds since wifi is garbage
Jun 07, 2021Guru - Experienced User
I would guess that the CM modem is getting a incorrect signal from the MOCA line and isn't compatible or getting a correct signal. the CM modem requires a specific signal for it to work right.
