wkw62's avatar
wkw62
Netgear CM500 vs CM500 NAS, What's the difference?
Netgear CM500 vs CM500 NAS, What's the difference? If there IS a difference, will either work with Time Warner Cable ISP?
  • wkw62's avatar
    wkw62
    Sep 21, 2017
    Thanks for the reply.
    I assumed they are the same (the spec sheets were identical).
    I don't know why companies give different model #s but don't tell us the diff, if any !
    Thanks again, and I really appreciate the email response (so I don't have to keep checking the forum to get an answer - the reason I don't usually use forums).
