GarrettSR5
Jul 07, 2021Aspirant
Netgear CM600 No Internet
I've had my CM600 for a few years now and over the past few months I would just randomly disconnect from my Xfinity service. Normally a simple reboot would solve the problem. But tonight I think some...
GarrettSR5
Jul 31, 2021Aspirant
Jul 31, 2021Guru - Experienced User
You've got errors in your line, your power levels are all over, and only 1 locked upstream.
Check your coax line for kinks, spliters, amplifiers, or signal attenuators. Remove them if you have them.
Check the line for old/bad/cheap/corroded/loose connections. Preferably, move the modem to right where the coax enters the home to prevent wiring in the home from being the issue. Then connect it and try it. if its still having issues, take the same screensnips and post them here. The isp might need to check the line in that case.
- GarrettSR5Aug 03, 2021AspirantThere is a one to two splitter in my basement but only one exit is used. I'll order a straight connector.
The connection from the pole to the house is exposed, that seems like it would effect the signal.
