DavidInWebb
Dec 23, 2020Follower
Netgear CM600 Requiring Frequent Reboot
Several months ago I had some type of electrical issue (lightening, power surge, whatever). I lost internet accesss. With the help of the Geek Squad it was pretty much determined that my Netgear ro...
Dec 23, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
