CaseyJ's avatar
CaseyJ
Follower
Aug 10, 2018
Netgear CM700 Cable Modem Issue
I'm getting connection via wifi but when I try to connect my laptop directly to the modem I get no connection. Very strange and can't figure it out. I'm having speed issues with Suddenlink and wanted to see what my speed was directly connected but can't get a connection when directly connected.
1 Reply
  • > I'm getting connection via wifi but when I try to connect my laptop
    > directly to the modem I get no connection. [...]
       A CM700 is a cable-TV modem, not a router, and not a wireless router.
    If you're "getting connection via wifi", then I'd guess that you have a
    wireless router somewhere.
       Cable-TV ISPs can be fussy about the equipment which you connect to
    their systems.  If you replace some (unspecified) router with a your
    (unspecified) "my laptop", then the ISP may see a different MAC address,
    and that may cause a connection problem.  You might want to contact your
    ISP about this problem.
