Retired_Member
Sep 02, 2019Netgear CM700, Spectrum 100 Mbps, Overkill ?
I'm looking to buy a Netgear (NG) CM700 (Spectrum recommend modem for 400 Mbps) and NG Orbi RBK50 router. I have the Sectrum (FL) 100Mbps plan. I know the NG CM 700 will not increase my speed. Will...
- Sep 02, 2019
I've found benefit with having more channels available in congested areas. Basically gives you some fall back if they've over sold the area.
I've a friend who was using a cm500 with 150mbps. constantly had slow downs or higher latency (even with good signals) because they'd oversold that service area. Upgraded to docsis 3.1 (the area had that option) and hasn't had trouble since.
So it basically depends on your area and ISP.
Sep 02, 2019Guru - Experienced User
I'm always a fan of over planning when it comes to stuff like this. I'd definitly go the cm700. In a 4 year span, i went from 100mbps service to 1gig service for around the same price. Calling in each year potentially means faster speeds for the same price or cheaper prices for the same speed. Either way, I'd go for a more robust router.
I'd even potenially look at the cm1000 if you plan on gigabit service at all.
