jsnyder1979
Sep 11, 2020Aspirant
Netgear CM700/Nighthawk AC4000 - High uncorrectables/power levels
So I had a CM1000 modem and Nighthawk AC4000 router over the past year without noticeable issues. Then at the end of July through August, I was having my Internet constantly drop out every day. Outsid...
Sep 11, 2020Guru - Experienced User
They need to send a new tech to check your line. If both modems are having the same issue, it isn't the modem.
And your power levels are all over the place. They should be withing 3.5dbmv of each other. You're way over that.
