Hyzers
Sep 25, 2022Follower
Netgear CMD31T US 1/2 Blinking Red and Orange
I can no longer connect to the internet since my modem started doing this. What does it mean when the US 1/2 alternates between blinking red and orange? (1/2 and 3/4 DS are solid green) There is no in...
Sep 25, 2022Guru - Experienced User
• 1/2 solid amber: Upstream Channel 1 is in use.
• 1/2 solid green: Upstream Channels 1 and 2 are in use.
• 3/4 solid amber: Upstream Channels 1, 2, and 3 are in use.
• 3/4 solid green: Upstream Channels 1, 2, 3, and 4 are in use.
• Off: No upstream channel is in use.
do you have a screen snip of the cable connections page? Actually shows your connections strength.
