Moemac
Dec 02, 2017Aspirant
Netgear D6300 Issues
Hi all, I am having an issue with my Netgear d6300 router. Now my situation is as follows. I live in a granny flat. The modem is located in the main house. there is a cable running to the granny f...
antinode
Dec 02, 2017Guru
You've chosen a "Cable Modems & Routers" forum to discuss your DSL
modem+router (being used as a plain router, I gather), and I can't tell
what "it" means in half of its occurences, but, ...
> All this leads me to believe that the router is at fault.
Seems that way. You might try the usual panacea, a full ("factory")
reset, and then reconfiguration. You can try saving and restoring the
settings, but if they're corrupt, then a manual reconfiguration might
work better.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual, and look for "reset".
- MoemacDec 02, 2017AspirantI already done a reset, if you mean by pressing in the button at the back, anyways im going to follow the link and your instructions and ill report back, thank you soo much for the reply
