Tillamookwaffle
Jul 02, 2019Follower
NETGEAR DGN2200V4 ROUTER SETUP - wifi speed issues
I've set up my DGN2200v4 as WAN only to use it as a router. ISP and LAN speed is 100 mbps. The modem is netgear nighthawk CM1100. WIFI is barely getting 5 mbps. I've changed the channel and lowered ...
Jul 02, 2019Guru - Experienced User
Please post about this in the DSL modem forum for your model modem:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Also be ware of older modems and WiFi, this model only supports the following:
IEEE® 802.11 b/g 2.4 GHz with some n features
So WiFi speeds maybe slow.
Might be time to upgrade WiFi.
Good Luck.
rahul6
Jul 02, 2019Aspirant
Thanks For Sharing This Informative Article ...
Searching For Best Earphones Under 1000 in 2019 then Click On This Link
https://phonespick.com/best-earphones-under-1000-in-2019/
