ZeroC00l
Jan 09, 2017Luminary
netgear DGND3700V2 NO-IP / Netgear Dynamic Host
For some reason after setting up a NO-ip / Netgear Dynamic Host, everytime I click on show status, it's telling me, update failed at 21:14 PM, 01/09/2017.The service provider is not reachable. ...
ZeroC00l
Jan 11, 2017Luminary
I am using Firmware version Firmware Version V1.1.00.26_1.00.26NA
Advanced / Advanced Setup / Dynamic DNS and click on Show Status No update action. There is no IP address on the Internet port.
I get that when NO-IP asked me to use the no-ip setting.
Now when I use NETGEAR setting, I get this, Update failed at 16:00 PM, 01/11/2017.The service provider is not reachable.
ZeroC00l
So this is so annoying, I have a problem, and Netgear nor NO-IP want to even get this working, NO-IP is saying Netgear is having issues with the API, but I am stuck here being tossed like a ping pong ball between to paddles. No one knows and no one helping, take your money and leave you hang to dry, typical so typical.................
- ZeroC00lJan 11, 2017Luminary
I am about to give up on this router, It's enough to sit here for 3 days troubleshooting it, some feature that don't work, and one wants to take responsibulity to fix a broken addition. No one from Netgear cares, no one no-ip cares. So I son't care, and thus my last product from Netgear. If you cannot come up with solution, or not even respond to my posts, your telling me you have no intrest in this. So I dont either.
- ZeroC00lJan 12, 2017Luminary
So I went to an older firmware, DGND3700v2-V1.1.00.21_1.00.21NA and tried the same settings, no go.
Then reinstalled DGND3700v2-V1.1.00.26_1.00.26NA restore defaults, and still no go.
Also it's not opening any ports on port forward at all, I add a random port, like 17777 and goto WhatsMyIP.org don't even see the port at all.
I don't know what the hell this is but it's pretty sad I use to have a Linksys, never, ever had a issue port forwarding with it, .Very very annoyed.
After more tinkering, If I enable remote access and goto whatsmyip.org, put in that port, it sees it. So why isn't it forwarding my ports?
