masaki415's avatar
masaki415
Follower
Jan 10, 2021
Netgear equivalent of xfi app?
Hello, I just purchased this modem, which replaced our xfinity modem. Three questions:
1) What's the Netgear equipvalent of the xfi app? I want to set a wifi access schedule for my kids' devices (automatically shuts off during certain hours), and get alerted when devices connect to our WiFi.
2) What's the difference between the 2.4 and the 5 Ghz? Which devices should connect to which?
3) How do I change the password that's imprinted on the modem?
Thank you!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the sections in the manual Specify Basic WiFi Settings and Set Up Parental Controls.
    You may have done this already. I can't tell from your message.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
    You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
    Cable Modems & Routers
    I will ask the Netgear moderator to move your message.
