mzbehaven365
Dec 03, 2015Follower
Netgear Genie 3700
Is it normal for one of my lights on my Netgear modem to turn amber and back to green?? The 2nd light after the power light is the one Im asking about. I dont believe that Ive experienced any outa...
DarrenM
Dec 03, 2015Sr. NETGEAR Moderator
Hello mzbehaven365
If you haven't seen any performance issues or dropping of internet then you should be fine. let us know if you find any odd things happening if so everyone here is happy to help with the issues.
DarrenM
mattingly23
Dec 28, 2015Aspirant
the light next to the power light turns amber and i lose internet then after a few minutes it comes back on
- DarrenMDec 30, 2015Sr. NETGEAR Moderator
mattingly23
I would check your cords first it could be a cable splitter causing a issue may want to remove it or replace it and see if the connection is better also check with your ISP see if they see issues with the connection.
DarrenM
