Grouch1357
Jul 31, 2018Guide
NETGEAR Genie Software for c3000 router
What is the released version of NETGEAR Genie for Windows? The installer is labeled 2.4.48 The installed application file/product version is 2.4.44 The “About” inside the running software is 2.4.5...
DarrenM
Aug 01, 2018Sr. NETGEAR Moderator
The about would be the correct version. 2.4.54
DarrenM
- Grouch1357Aug 01, 2018Guide
The problem is that when version/revision tracking software such as SUMo sees the 2.4.44 as the current version, it thinks that is the real version number.
