Cajun65
Dec 30, 2015Follower
Netgear Genie will not work on my new Windows 10 machine
To Whom I just got a new laoptop computer with windows 10 and Netgear Genie will not open, it does a short search and then wants to shut down the Genie. My new laptop has window 10 has Windows 1...
DarrenM
Dec 30, 2015Sr. NETGEAR Moderator
Hello cajun65
Have you tried to open the genie software as administrator? also may want to reinstall it.
DarrenM
docbhill
Jan 01, 2016Aspirant
I am having the same problem and I have reinstalled the software numerous times but still have the problem where the program does not want to start. I'm assuming this is due to compatibility issues. Please help.
Thanks
Barron
- nickva0517Jan 01, 2016Tutor
I had the same situation following Windows 10 install. I went to Netgear to find the latest Genie install, downloaded, and installed. Seems good as before when I was on Windows 8.1. Hope that helps you.
