DewyB's avatar
DewyB
Netgear GS608v3 not opening control panel
I have tried routerlogin.com and .net, 192.168.0.1, 192.168.1.1, and performed an ipconfig and tried my defalut gateway ip. NOTHING opens the control panel so I can open a port.  I should get a po...
  • antinode's avatar
    Nov 26, 2018
       A GS608v3 is an unmanaged switch.  It has no "control panel".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get what you can find.  Read.
    > [...] About to pull out my hair and bash router with hammer. [...]
       You'll need to find a "router" first; a GS608v3 is not a router.
    > [...] No place to insert a paper clip and reset to factory settings
    > either. [...]
       Unmanaged switch.  Not a router.  No "factory settings".
    > performed an ipconfig and tried my defalut gateway ip. [...]
       "tried" how?  Some web browser or other?  On some computer/device or
    other?  Connected how to what?  What, exactly, was your "my defalut
    gateway ip"?  What, exactly, happened when you "tried" each of these
    things?
       Do you _have_ a router, or only the GS608v3?  What, exactly, is
    connected to what, exactly?  What, exactly, are you trying to do?
       As usual, showing actual actions with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
