ForceTen
Sep 23, 2021Aspirant
Netgear issued firmware on 9-20-2021 to patch vulnerability CVE-2021-40847. Is my C7100V vulnerable
My NETGEAR NIGHTHAWK model C7100V aka AC1900 Router-Modem is functioning now with my ISP Comcast / Xfinity. The current 'best' firmware NetGear lists is version 2.01.45, which has been around for mo...
- Sep 24, 2021
ForceTen Ok, this subject has come up before:
https://community.netgear.com/t5/Cable-Modems-Routers/New-C7100v-Comcast-Firmware/td-p/1942256
So clearly, Comcast do push out firmware updates when required, otherwise the user in the link above, wouldn't have had the update pushed to them.
The firmware you have mentioned, V2.01.45 does seem to be the only firmware update that has so far been pushed out.
How long have you had this modem cable router? Is it an ISP supplied piece of kit?
The other firmware you linked to, has nothing to do with your model of router/modem, it is for the R7000 AC1900 model.
Others have mentioned the C7100v before, just use the search function:
My personal advice, if you're worried enough about security/firmware and this model of router isn't making you feel comfortable, if it's an ISP supplied router, ask them if they'll take it back or swap it for a newer version, or buy a different model replacement, but make sure you know first what your'e purchasing and that it's compatible for your ISP setup.
Sep 24, 2021Guru - Experienced User
Please be sure to visit and post about any C7100 modem information in the cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
