CaptnMrgn63
Apr 01, 2019Aspirant
NETGEAR modem and router
Has anyone had a MacBook Pro which says it’s connected to NETGEAR and internet but can’t use safari or search engines or anything to surf the web.
DexterJB
Apr 02, 2019NETGEAR Moderator
- CaptnMrgn63Apr 03, 2019Aspirant
C7100
- antinodeApr 08, 2019Guru
> [...] a MacBook Pro which says it's connected to NETGEAR and internet
> [...]"connected" how? Wired? Wireless? What, exactly, says what,
exactly?> [...] can't use safari or search engines or anything to surf the web.
What happens when you try? Can you reach the (unspecified) router's
management web site ("routerlogin.net", or similar)?"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.What is the IP address (et al.) of the Mac?
