modem_brat's avatar
modem_brat
Follower
Jun 04, 2020
Netgear Modem CM1000 v2: How many devices can I connect?
I own the Netgear CM1000 v2 modem that I have connected to a netgear switch via Cat 7 Lan cable.
I can connect to the modem using my laptop, but the modem refuses to connect to my other home devices.
My home network setup:
Wired: Modem--switch-->devices (not working: can connect the router and a laptop but the modem doesn't 'see' other devices)
Wireless: Modem-->switch-->Nighthawk 7000 router (works without any problems)
I called Xfinity and they confirmed that they aren't placing any limits on the number of connected devices on my modem.
When I connect o my modem via wireless, I can't see any options tha would allow me to examine/change the number of connected devices..
How can I resolve this problem?
1 Reply
  • > I own the Netgear CM1000 v2 modem that I have connected to a netgear
    > switch via Cat 7 Lan cable. [...]
       Not a good plan.  (And "a netgear switch" is not a very detailed
    description of that device.)
       Yup.  Less vaguely, additional devices are not getting connected to
    your ISP through the modem.
    > problems)
       Yup.  And you should be able to get the same results if you remove
    the switch.  (Assuming that "Nighthawk 7000" means "R7000".  Look at the
    product label.)
       Not strictly true.  They limit you to one device (one external IP
    address).  That one device is normally a NAT router (like, say, an
    R7000) which would allow your one external IP address to serve multiple
    devices.  Whoever you talked to probably assumed that you had a router
    connected to your modem, and they don't limit the devices attached to
    your router.
       Connect your modem to a router (WAN/Internet port), and connect your
    client devices to that router.  If you have too many wired devices for
    the LAN ports on the router, then you can connect a network switch to a
    router LAN port, and then connect more devices to that switch.
