RFChase
Jun 02, 2019Aspirant
Netgear modem not working well with apple router
I replaced the xfinity leased modem with the Netgear CM500V. My router is an Airport Extreme. Since installing the new modem the router is not working as well. It's range is severly diminished. C...
RFChase
Jun 03, 2019Aspirant
Both the speed and the range of the wifi are compromised. The internet speed on the computers is fine. The computers are wired to the router by ethernet cable. They are not plugged into the modem.
Jun 03, 2019Guru - Experienced User
That would be a wifi problem at the router, and not the modem.
Contact the routers mfr for help and information.
Good Luck.
