Prateek's avatar
Prateek
Netgear N300 WIFI Cable modem Router dropped the internet speed from 25MBPS to 7-8 MBPS
Speed dropped from 25MBPS to 7-8 MBPS which is getting difficult to stream one device. When reached out to Netgear technical support, they started with informing about extended warranty to support even before understanding the problem. Asking to pay $ 89.00 for troubleshooting. Please find the steps taken by myself to trouble shoot:
1. Connected directly using cable, downloading speed was 28.38, when tried with WIFI, it reduced to 4.39 - 7.82 mbps. This explains modem is functioning fine.
2. Connected neighbors router N600 to modem, downloading speed increased to 25.72 mbps. This explains problem is with the internal router.
3. I have not moved the router / made any changes, suddenly there is a drop in the speed which is unexpected. When asked for help, they start with payment of 89.99 for technical support.
4. I have gone thru every option under
http://kb.netgear.com/app/answers/detail/a_id/1114 and
http://kb.netgear.com/app/answers/detail/a_id/1110
which did not resolve.
5. Under NetGear Genie, i have changed the channel from AUTO to 1 / 6 / 11 and tried all the setting changes, still did not work.
6. Finally i decided to do Factory reset which ideally gets back to first day, still the speed is same.
I still have the hardware warranty but unable to use even when i have tried all the possible scenario's. I get new Router for $ 75.00 from Netgear which will work as i have tried my neighbors.
Please help me in resolving this problem as technical support needs to be provided for product which was working fine and suddenly stopped working due to some update / hardware issues.
Thanks
Prateek
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    What's the exact model number and version of your router?
    Do you have the latest firmware installed on the router? If yes, reflash and reset the router.
    Is the problem happening only on the wireless, correct?
    Which signal you're connecting on the router (2.4GHz or 5GHz)?
    How many wireless devices are connecting to the router?
    Do you have the latest driver installed as well on your wifi adapter?
    • Prateek's avatar
      Prateek
      Model written on router is C3000, MAC : A06391627508, Serial: 3KW2557100B10
      How will i know if the firmware was updated? As per Netgear, ISP will send the update which is done automatically. I have not done personally. Let me know if i have to update the firmware, i would require procedure to do it.
      Problem is only in the wireless.
      2.4GHz
      We have TV with chromecast, MAC, 1 IPhone.
      I'm not aware of installing latest driver, also i have not been informed.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Prateek
        I have something you can try go to the Advanced- Advanced Setup-Wireless settings and un check the WMM box and see if this improves the wifi speeds.
        DarrenM
