Sho
Jun 18, 2016Follower
Netgear N600 cable modem router model C3700
N600 is acting strange today (this morning), my PC was not able to connect to yhr router, after power off and on, power led light on, a few seconds later, the next 3 led lights flash 6 times simultan...
DarrenM
Jun 24, 2016Sr. NETGEAR Moderator
Hello Sho
I would try to factory reset the modem if that fails you may want to check with your ISP could be a connection issue. And if something is wrong with the modem you may want to contact Netgear support if your modem is still under warranty.
DarrenM
