Retired_Member
Oct 08, 2015Netgear needs to contact TimeWarner Cable ISP - C6300 Firmware update Needed
TimeWarner Cable ISP has not provided any firmware updates for the C6300 modem/router device in over a year. The fixes Netgear has been providing, including NAT Loopback, security, USB Readyshare en...
tchavez3
Jan 31, 2016Aspirant
my cmd31t keeps disconnecting from the internet. I called time warner in regards to firmware update but they where clueless. Is there a way to get the firmware from you and upload it to the modem?
DarrenM
Feb 03, 2016Sr. NETGEAR Moderator
Hello Tchavez3
All firmware is pushed out by the ISP on cable modems. But if you are having constant disconnects check your cables also if you have a cable splitter try removing that and connect the modem directly to the wall. If the problem persists you may want to contact TWC and have them send a tech out to check your lines.
DarrenM
