Retired_Member
Oct 08, 2015Netgear needs to contact TimeWarner Cable ISP - C6300 Firmware update Needed
TimeWarner Cable ISP has not provided any firmware updates for the C6300 modem/router device in over a year. The fixes Netgear has been providing, including NAT Loopback, security, USB Readyshare en...
DarrenM
Oct 09, 2015Sr. NETGEAR Moderator
Hello circadianswing
I have sent you a Private Message about this issue.
DarrenM
- Retired_MemberNov 05, 2015Just checking to see if there was any new submission to TWC, as per their response, they are waiting on you. From TWC Management... Re: Firmware upgrade for NetGear C6300 modem/router combo
3 weeks ago
The last firmware that NetGear has approved through our engineering team was V1.02.19. NetGear and other modem manufacturers may continue to release firmware updates, but those need to be submitted to our engineering team for testing before they become available to customers. When NetGear submits their latest firmware, we can begin the testing and validation process.
Thank you.
TWC-PhilB
Community Manager
Time Warner Cable- talkprodNov 19, 2015Aspirant
Has anything more been done by Netgear to present this firmware upgrade to Time Warner? Each side is putting responsibility on the other, and it appears that nothing has been done. Can you please advise?
- tchavez3Jan 31, 2016Aspirant
my cmd31t keeps disconnecting from the internet. I called time warner in regards to firmware update but they where clueless. Is there a way to get the firmware from you and upload it to the modem?
- DarrenMFeb 03, 2016Sr. NETGEAR Moderator
Hello Tchavez3
All firmware is pushed out by the ISP on cable modems. But if you are having constant disconnects check your cables also if you have a cable splitter try removing that and connect the modem directly to the wall. If the problem persists you may want to contact TWC and have them send a tech out to check your lines.
DarrenM
- MikeModemMar 06, 2016Aspirant
Can someone from Netgear provide the latest firmware update version for the C6300 for Brighthouse Networks ISP? My current version isn't listed in the Netgear Modem Matrix, and the version listed in the matrix looks to be newer. According to Brighthouse tech I have the latest version V1.02.20; the new one listed is V1.02.21, or maybe V2.01.14. Not sure since Brighthouse isn't listed, and don't know if they are part of TWC or Charter? My modem is working OK, but I want to insure I have the latest updates for any fixes, speed issues and security updates. Also, do they push automatically after received from Netgear, or do they do so at their discretion? Thanks.
- DarrenMMar 09, 2016Sr. NETGEAR Moderator
Hello MikeModem
All firmware is pushed out by the cable ISP we send all firmware to them first they certify it and make changes they see fit then push it out to all of there customers. So you can not update the firmware manually. If they say they have a newer firmware have them try to send signals to the modem and a reboot it should sync up and get the latest firmware. But if you are not having any issues with your modem I wouldn't worry about the firmware to much 1.02.20 to 1.02.21 sounds like a really small change.
DarrenM
