ColinZ
Aug 23, 2020Tutor
Netgear Night Hawk CM1100 does not work with Google Nest Wifi, any guidance? Xfinity gigabit plan
Hi everyone, Asking for some desperate advice here as I have spent the entire weekend googling and reseraching, and still have no luck. I got the brand new Netgear Night Hawk CM1100 (DOCSIS 3...
ColinZ
Aug 27, 2020Tutor
Thanks for the reply, pmiller! The URL link was cut short when posted but I was able to find the full URL link via the search on the community form. But it looks like the page expired and the link no longer works. Would you please kindly post the solution that worked for you or perhaps repost the full link again at the beginning of the message? Thanks so much!
Aug 27, 2020Guru - Experienced User
I would make contact with Google support and get additional help and information regarding there router wifi product. They should have information you need to get there router connected. Just be sure your connecting the router with a good quality LAN cable to port #1 on the CM1100 modem. A power off of the modem and router should be done for 1 minute then back on. Wal thru Google routers setup wizard and see if it will get it setup with the modem. If other wifi routers are connecting to the CM modem and the Google one isn't, then the Google router maybe faulty. Something to ask Google about.
ColinZ wrote:Thanks for the reply, pmiller! The URL link was cut short when posted but I was able to find the full URL link via the search on the community form. But it looks like the page expired and the link no longer works. Would you please kindly post the solution that worked for you or perhaps repost the full link again at the beginning of the message? Thanks so much!
