ColinZ
Aug 23, 2020Tutor
Netgear Night Hawk CM1100 does not work with Google Nest Wifi, any guidance? Xfinity gigabit plan
Hi everyone, Asking for some desperate advice here as I have spent the entire weekend googling and reseraching, and still have no luck. I got the brand new Netgear Night Hawk CM1100 (DOCSIS 3...
Malena519
Mar 04, 2021Aspirant
I cannot connect the Google nest either. I deleted both the Google WiFi and the Home app, reset the nest to factory defaults, nothing helped. Extremely frustrating! Of course nobody in Customer Service at Google is available. I am going back to my old modem tonight so my daughter can attend class in the morning. After school, I will reach out to Google Neat CS and See of they are able to help. If not, the Nest goes back to Costco. The modem stays.
- FURRYe38Mar 05, 2021Guru - Experienced User
When connecting a wifi router to the CM modem, power OFF both modem and router for 30 seconds, then power ON the modem, then power ON the wifi router. The router should get connected to the modem. Review the routers user manual on how to check status on the WAN or Internet port of the router.
Be sure your using good quality LAN cables. CAT6 is recommended.
Be sure LAG is disabled on the CM modem.
Try a different router with the CM modem as well.
Malena519 wrote:
I cannot connect the Google nest either. I deleted both the Google WiFi and the Home app, reset the nest to factory defaults, nothing helped. Extremely frustrating! Of course nobody in Customer Service at Google is available. I am going back to my old modem tonight so my daughter can attend class in the morning. After school, I will reach out to Google Neat CS and See of they are able to help. If not, the Nest goes back to Costco. The modem stays. - SMW-308Mar 05, 2021Aspirant
My experience was frustrating too because I spent hours with Cox cable and reearching issues with Google Nest with no solution. My problem was solved once I called Netgear.
I made the assumption that I could use both of the Ethernet connections on the back of the modem to connect to the internet. Netgear told me that for my internet service (0.5 G) I should only use one (either) of the connections. So, the service comes into the Netgear modem, is connected to the Google Nest router, then goes from the router to a switch that provides the connections to all my other cabling. The two Netgear Ethernet connections are used for a 1.0+ G configuration that I do not use. Pretty simple, right?
This may not be your situation but once I used this configuration, everything worked. Be sure that the internet (globe) icon on the Netgear modem is solid before you power up the Google Nest.
Hope this helps.
BTW -- After powering down the modem, wait about 5 minutes. Seems excessive but powering up after a minute sometimes did not work.
