NutgearsGrindin
Dec 30, 2024Tutor
Netgear Nighthawk 5ghz WiFi not uploading files
I have seen multiple threads about CAX80 Netgear Nighthawk not allowing people to upload files on 5g WiFi, I am also having this problem. I recently “upgraded” my modem to this device. I am only able ...
Retired_Member
Jan 06, 2025I appreciate your efforts, but unfortunately I had the same result as the person who replied to you in this Reddit thread: I clicked the "Save Debug Log" button and the page just never resolved and nothing was downloaded. I gave it about five minutes, after which I had to power off the router because I couldn't even return to the settings pages. Upon rebooting, I was forced to go through the new password / security questions setup again.
I opened a case since I'm still under warranty. I'll update here if anything comes of it.
Jan 07, 2025Guru - Experienced User
What browser were you using? I use MS Edge and have been able to get logs from my CAX80.
Might clear out browser caches before doing to the debug page as well.
- Retired_MemberJan 07, 2025
FURRYe38 I'm using Arc (which is chromium-based like MS Edge, if you're unfamiliar with it). I'm under the gun on a project at the moment, but I'll try clearing the cache / using another browser when I'm free.
FURRYe38 wrote:What browser were you using? I use MS Edge and have been able to get logs from my CAX80.
