Jesse_Zuniga
May 06, 2020Guide
Netgear Nighthawk AC1900 (C7000-100NAS) Disconnect issues
My Netgear Nighthawk AC1900 (C7000) has been experiencing frequent disconnects from both cable, wifi, and ethernet simultaneously. This has been going on for over a month now. In the earlier s...
May 06, 2020Guru - Experienced User
Log into the cable connection page on the modem and get the screen snip of your cable connections. This shows the connection back to the isp. I've long ago learned not to trust an ISP when they say "the line is fine".
also, if you have any splitters, amplifiers, attenuators in line, remove them.
Jesse_Zuniga
May 06, 2020Guide
plemans wrote:get the screen snip of your cable connections
The cable connection screenshots are included at the end of the album linked above.
plemans wrote:if you have any splitters, amplifiers, attenuators in line, remove them.
I don't have any. The ISP tech also checked for those when he was here.
