MikeDin
Mar 13, 2023Tutor
Netgear Nighthawk AC1900 cable modem router + voice
We have a phone connected to our cable modem router. The phone line goes dead periodically (no dial tone). When I reboot the router, the phone line comes back on line, but a day or two later the sa...
MikeDin
Mar 13, 2023Tutor
Attached is the cable connection info. The actual model number is C7100V.
Kitsap
Mar 13, 2023Master
MikeDin wrote:Attached is the cable connection info. The actual model number is C7100V.
Good job on posting your signal level page. The signal power levels are not out of line. They could be improved. The in home coax wiring could have an impact on the power levels. Will wait and look at your logs when posted.
How many phones/base stations do you have connected to the RJ11 output of your gateway?
- MikeDinMar 13, 2023Tutor
We've got one Panasonic base station hard-wired to the Tel 1 output on the modem. Attached are the logs. Thanks for you help.
- KitsapMar 13, 2023Master
MikeDin wrote:We've got one Panasonic base station hard-wired to the Tel 1 output on the modem. Attached are the logs. Thanks for you help.
This appears to be your router log. Do you have a specific cable modem log?
- plemansMar 14, 2023Guru - Experienced User
its called event log in the settings
