UltraR3actor
Oct 12, 2020Follower
Netgear Nighthawk AC1900 Speeds
I've been having issues trying to get my full downstream/download speeds. I have the 600 Extreme plan from Comcast and the modem router I was renting actually output the full speed. I recently switched over to my new modem router C7000v2 to get out of the rental payments but I have been noticing that it is just outputting 250-260 and not any higher. What could be causing this?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853 - plemansGuru - Experienced User
Are you checking those speeds wired or wireless?
