KatelynG
Jul 31, 2022Follower
Netgear Nighthawk ax6 cax30 no wifi
I have had this router for about 6 months and it has been working fine. All of a sudden the wifi stopped working. I have unplugged and replugged everything back in and have also done the factory reset...
Jul 31, 2022Guru - Experienced User
Is the front Wifi LED ON after you factory reset the modem and setup from scratch?
Press the wifi button on the front of the modem for 5 seconds to see if this changes anything.
