ckillen468
Jan 04, 2017Aspirant
Netgear Nighthawk C7000 - Slow Download Speed through ethernet ports
Just bought this for use with my cable ISP. Called them before hand and they assured me that many customers were using the same modem/router for their service. I am paying for 200mbps down and when c...
ckillen468
Jan 06, 2017Aspirant
Not sure that's the issue. On WiFi I am getting consistently faster speeds on the 5ghz band. This leads me to think there is a setting in the router that needs to be adjusted.
- DarrenMJan 11, 2017Sr. NETGEAR Moderator
Hello ckillen468
Shouldn't be anything that needs changed to get full speeds across the lan connection you may want to try and factory reset the modem incase something from a firmware update messed up.
DarrenM
