Jaylampin
Aug 14, 2016Aspirant
Netgear NightHawk C7000 Modem/Router. Unable to login to modem after a few days of use.
Netgear NightHawk C7000 Modem/Router. I'm unable to login to modem after a few days of use. I've read that you have to reboot/reset to default to be able to back into the router (via ip addres)....
DarrenM
Aug 16, 2016Sr. NETGEAR Moderator
Hello Jaylampin
Is the Default gateway address changing after a couple of days? do you try both ways 192.168.0.1 and www.routerlogin.net? When you try to log in are you directly connected via ethernet?
DarrenM
- JaylampinAug 16, 2016Aspirant
Default gateway is not changing. It's still 192.168.0.1.
When I login, i usually go via 192.168.0.1, but since you asked, I did try the url routerlogin.net and that failed also.
Like I said, it takes a power cycle to log back in. It'll work for a couple/few days, then same issue.
I've even reset it to default hoping that would fix the issue permanently, but it has not.
For the record, i can get to the internet and connect to all my other devices fine, I just can log into the C7000 router/modem.
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.0.25(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, August 16, 2016 10:27:09 AM
Lease Expires . . . . . . . . . . : Wednesday, August 17, 2016 10:27:12 AM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
