Jaylampin
Aug 14, 2016Aspirant
Netgear NightHawk C7000 Modem/Router. Unable to login to modem after a few days of use.
Netgear NightHawk C7000 Modem/Router. I'm unable to login to modem after a few days of use. I've read that you have to reboot/reset to default to be able to back into the router (via ip addres)....
DarrenM
Aug 16, 2016Sr. NETGEAR Moderator
Hello Jaylampin
Is the Default gateway address changing after a couple of days? do you try both ways 192.168.0.1 and www.routerlogin.net? When you try to log in are you directly connected via ethernet?
DarrenM
Jaylampin
Aug 16, 2016Aspirant
Default gateway is not changing. It's still 192.168.0.1.
When I login, i usually go via 192.168.0.1, but since you asked, I did try the url routerlogin.net and that failed also.
Like I said, it takes a power cycle to log back in. It'll work for a couple/few days, then same issue.
I've even reset it to default hoping that would fix the issue permanently, but it has not.
For the record, i can get to the internet and connect to all my other devices fine, I just can log into the C7000 router/modem.
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.0.25(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, August 16, 2016 10:27:09 AM
Lease Expires . . . . . . . . . . : Wednesday, August 17, 2016 10:27:12 AM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 8.8.8.8
