Konanpa
May 28, 2020Initiate
Netgear Nighthawk C7000v2 Wireless work fine but no wired connection via LAN
Just purchased C7000 Nighthawk - installation was easy. worked with ISP provider Cox. No issues. Wireless is working fine. However, I cannot get the modem/router to recginzie any of the LAN ports...
May 29, 2020Guru - Experienced User
What LAN devices do you have connected?
Be sure to swap out LAN cables with good quality cables, CAT6 is recommended.
Konanpa
May 29, 2020Initiate
I used the previous cable I had with prior device. They are CAT6 cables. Any other ideas on why these devices wouldn;t register. It is to my Samsung TV, Panasonic Blu-Ray and my Denon Receiver.
- FURRYe38May 31, 2020Guru - Experienced User
Do you have any wired devices that are working when wire connected or is all devices not working over wire?
Has a factory reset and setup from scratch been performed since last update?
