Mattmtz
May 17, 2023Aspirant
Netgear nighthawk c7100v cable modem router name and password change
I have a connection and ive activated it twice but everytime i go in ti change the name of the wi-fi and password, it says it has a “configuration error the router could not apply my new settings. Che...
Kitsap
May 17, 2023Master
Mattmtz wrote:
I have a connection and ive activated it twice but everytime i go in ti change the name of the wi-fi and password, it says it has a “configuration error the router could not apply my new settings. Check wifi connections and try again.” I check and my wifi is working but i cant change the name or password? Please help.
How are you trying to change the Wi-Fi configuration? Are you using a mobile device like a phone or a tablet?
If yes, you need to change to a real computer with a web browser and connect to the C7100v via an Ethernet cable. If not possible with an Ethernet cable, a connection via Wi-Fi should work.
- MattmtzMay 17, 2023AspirantMy modem is connected via ethernet cable and yes im trying to change it on my phone
