Mattmtz
May 17, 2023Aspirant
Netgear nighthawk c7100v cable modem router name and password change
I have a connection and ive activated it twice but everytime i go in ti change the name of the wi-fi and password, it says it has a “configuration error the router could not apply my new settings. Che...
Kitsap
May 17, 2023Master
Mattmtz wrote:
I have a connection and ive activated it twice but everytime i go in ti change the name of the wi-fi and password, it says it has a “configuration error the router could not apply my new settings. Check wifi connections and try again.” I check and my wifi is working but i cant change the name or password? Please help.
How are you trying to change the Wi-Fi configuration? Are you using a mobile device like a phone or a tablet?
If yes, you need to change to a real computer with a web browser and connect to the C7100v via an Ethernet cable. If not possible with an Ethernet cable, a connection via Wi-Fi should work.
Mattmtz
My modem is connected via ethernet cable and yes im trying to change it on my phone
- KitsapMay 17, 2023Master
Mattmtz wrote:
My modem is connected via ethernet cableTo a computer? If yes, Mac or Windows? If Windows, version 10 or 11?
What web browser are you using? Edge? Firefox? Chrome? Something else?
- MattmtzMay 17, 2023AspirantWindows 11 and i use brave browser
Mattmtz wrote:
Windows 11 and i use brave browserRecommend you try a different web browser program. Before you connect to your C7100v, go in to the settings on the browser and clear the cache and any password information you have saved for the user interface.
Brave should work. I have good success with either Firefox or Edge.
